3 flavours available
4GB/32GB
4GB/64GB
4GB/128GB
Highlights as Found:
Amlogic S905X3
Amlogic S905X3 applies quad-core Cortex-A55 processors, which is described as an "advanced application processor designed for hybrid OTT/ IP Set-Top Box (STB) and high-end media box applications. The Cortex-A55 cores deliver up to twice the performance compared to Cortex-A53 in memory benchmarks, and a more typical 20 to 30% performance improvement for common tasks at the same frequency.
Android 9.0 OS
It is based on the latest Android 9.0 OS, with high speed and smooth performance, which is designed to turn your regular TV into a smart one.
8K UHD Resolution
True 8k picture resolution can be as high as 7680*4320 to achieve 16 times of 1080p picture accuracy. The TV box supports 4K output.
Screen Mirroring
Supports DLNA, Miracast, Airplay. You can play games and watch movies on the big screen.
Faster Signal Transmission
The TV Box supports dual-band WiFi and up to 1000 Mbps LAN for more stable and faster signal transmission.
Geekbuying
