Maskroom in magicsee N6 max RK3399
    My magicsee N6 max RK3399 not working anymore I tried to upgrade it via cable;and sdcard, but the device didn't recognize it,
    can you help me please to use MaskRom mode to repair the system.
    Ineed to short the pinout to enter maskrom mode.
    Help me please !!
    Originally posted by zakariach View Post
    Help me please !!
    Hi ,
    looks your Nand has no Pins , what about a Picture of the other side ???
    where did you bought it , maybe Seller can help ,
    greetings / gefattern
      Hi ,
      thanks you for your reply
      I uploaded other picture for the tv box , you can see if has the pin ?
        Hi ,
        look here :
        this is for X99 Box but you can fimd many Infos here , think User "bergamesk" had a N6 , but i dont know if
        he knows where to short , what Tool did you use for SDCard ??? , think it did not work correct , there are
        only 1 or 2 working Versions , later i can upload a working one , if needed ,
        Hint : always use the latest Drivers & Tools
        good luck / gefattern
          Hi ,
          look here :
          Hi ,
          here the N6 Thread :
          MAGICSEE N6 MAX TV Box RK399 Android 7.1 4GB DDR4 + 32GB ROM 2.4G + 5G WiFi 1000Mbps USB3.0 OTG BT4.1 (https://www.gearbest.com/tv-box/pp_009237496768.html?wid=1433363&lkid=19629879) 20180929114948_50433.jpg Specification Brand: Magicsee Type: TV Box GPU: Mali-T860MP4 CPU: RK3399 Core: Cortex A53,Dual
          forgot it yesterday , any News ???
            Hi ,
            There is nothing new yet,
            I have sent a message to the company, and I haven't received a response yet
            • gefattern
              gefattern commented
              Editing a comment
              Hi ,
              please what SDTool Version did you use , i think you got a not correct working one ???
            i used RK3399 upgrade Tools , Rockchip Create Upgrade Disk Tool v1.53 ,RockChip_Batch_Tool_v1.8 ... but the box d'didnt does not respond , becouse the the bootloader is damaged .
            If you have any idea please tell me
            Thank you
              Thank you
                Thank you
                Hi ,
                later i upload a working Version of SDCard Tool , hope it helps to restore your Box ,
                think your Version is one of the many not working Versions , what Drivers did you use ???
                  Hi ,
                  here is the RKDiskTool :
                  RKDiskTool.zip
                  I was able too restore my X99 with it ,
                    Try this maybe
                    THe heat sink is spring mounted with plastic bolts and may be covering nand pins
                    Can be easilly removed by pinching bolt on backside of pcb with needle nose pliers push through and remove heat sink
                    gjwa yzma
                      Originally posted by freddy View Post
                      Try this maybe
                      gjwa yzma
                      Link : image 1
                      LINK: image 2
                        Link : image 1
                        LINK: image 2
                        Greetings
                        You are still working on this Project from May 2020?
                        From image 1 i see you have removed Heat Dissapate
                        Unfortunately that confirms what gefattern posted #2
                        No success with SD Card ....
                        Maybe go to Post #4 and follow link to thread
                        Page 46 at the Bottom
                        last Post has pic/image of Pinout for Maskrom
                        If your board is the same try that method.
                        Good luck
                        Happy |Testing>
