GUIDE FOR INSTALL TWRP ON MECOOL KM1
    I finally got TWRP for our KM1.
    Here are the steps
    1. On the Amlogic burner, burn the Alvatech image file version for Gt1 Mini2, which you can find here https://forum.freaktab.com/forum/tv-...9-0-pie-s905x3 . You will not lose DRM if select only normal erase and don t select overwrite keys.
    2 When the process finish, without closing the Amlogic burner, open the FASTBOOT folder in my zip, then open OpenCmd, then enter the following commands
    update bulkcmd fastboot
    IMPORTANT/ command return an error but ignore it
    fastboot flashing unlock
    fastboot flashing unlock_critical
    fastboot erase data
    fastboot flash dts dt.img
    fastboot flash vbmeta vbmetapatched.img
    fastboot flash bootloader bootloader.img
    fastboot reboot
    3- Start KM1 on the TV by holding down the reset button on the AV connector and release it when the Alvatech logo is displayed. If it does not work for the first time, disconnect it from the power plug and try again. This will work at the second time.
    4- We are currently in TWRP, but there are some errors that need to be corrected in relation to different sections. To correct the DATA and CACHE, just format the DATA and wipe CACHE, to correct the system, vendor, odm and product, use TWRP to flash the image files contained in my zip in their appropriate sections by TWRP.
    5 Now if you want erase all partitions completely for a major clean.
    Now we have our TWRP for KM1 fully functional and ready for new roms!
    LINK FILES KM1
    UPDATE!
    I noticed an additional bug in the TWRP after that I performed the procedure. System error during flash rom. Then perform this additional step
    Copy the fstab and twrp.fstab files to /etc via TWRP file manager and give it the right chmod 755 permissions. Then restart recovery. It is now fully functional.If you want to restore a backup and you don't see SYSTEM know that all the backup files related to SYSTEM must be renamed from system to system_root.
    Fix LINK
    The real modding started by loading the Vasily backup that you can find here https://mega.nz/file/DAs3lTxa#8DA2TK...JHGthoaVxdAVww here instead the video https://www.youtube.com/watch?v=XsZeHgH-8OU
