X96 mini not working
    Hello,
    I was trying to flash my X96 mini with X96MINI_3.01.2019.img and now all I see is the red light.
    Now I'm trying to put the stock image back in order to bring it to life but without any luck.
    What happens is that it gets to 98 % and gives an error when trying to download bootloader.partition.
    I've tried many ways with different versions of Usb burning tool, with the reset presed, with power plugged in, etc.
    USB burning tool detects it fine with or without the reset button pressed. I also tried with the card maker.
    Anybody has an idea?
    Micky
    [21:20:47 553][HUB2-2][Inf]--download store system sparse 1536810376
    [21:20:47 553][HUB2-2][Inf]--Send download command success
    [21:20:47 571][HUB2-2][Inf]--Read command status success
    [21:23:50 601][HUB2-2][Inf]--Transfer complete
    [21:23:50 602][HUB2-2][Inf]--Send download get_status command succeed
    [21:23:50 606][HUB2-2][Inf]--get_status success
    [21:23:50 606][HUB2-2][Inf]--verify sha1sum 6fcff7a395c69d9ea2913b5572387edd18ef0cf2
    [21:23:50 606][HUB2-2][Inf]--Send verify cmd succeed
    [21:23:50 606][HUB2-2][Inf]--ItemSize: 1536810376
    [21:23:50 606][HUB2-2][Err]--change timeout to 300s
    [21:24:07 706]Read BulkStatus return 0: Continue:34, sleep 3s
    [21:24:24 720]Read BulkStatus return 0: Continue:34, sleep 3s
    [21:24:41 435]Read BulkStatus return 0: Continue:34, sleep 3s
    [21:24:58 718]Read BulkStatus return 0: Continue:34, sleep 3s
    [21:25:01 718][HUB2-2][Inf]--Get verify status success
    [21:25:02 218][HUB2-2][Inf]-------------Download bootloader.PARTITION-----------
    [21:25:07 219][HUB2-2][Err]--IOCTL_IDENTIFY_HOST_Handler ret=-116 error_msg=libusb0-dll:err [control_msg] sending control message failed, win error: The I/O operation has been aborted because of either a thread exit or an application request.
    [21:25:07 226][HUB2-2][Err]--[0x30401002]UBOOT/Partition bootloader/Identify/USB Control setup error
    [21:25:07 226][HUB2-2][Inf]--Close device handle 0x000004e0
    Have you try window 7 to flash??
      Thanks for your answer.
      I should have mentioned I am using a Win 7 64 bit PC
