Supports 2*3.5 inch HDD NASdolby DTS Android 9.9 2.4G+5.8G WIFI Gigabit LAN
Make Your Home A Cinema
Beelink GS-King X adopts the latest Amlogic S922X-H chip (Quad-core Cortex-A73 @ 2.2 GHz + Dual-core Cortex-A53 @ 1.8 GHz), which is the strongest chip in TV box at present. This TV box features high-end Hi-Fi lossless sound quality and Dolby sound effects to give you an immersive hearing and viewing experience, which is one of the most cost-effective products.
DTS Listen + Dolby Audio
Beelink GS-King X features DTS listen + Dolby audio decoding, offering Hi-Fi losses sound quality to you for an immersive experience.
Amlogic S922X-H Hexa-core CPU + Hexa-core ARM G52 MP6 GPU
With the high-performance CPU + GPU, making the GT-King Pro TV box runs fast and smoothly with excellent heat-dissipation, never worry about buffering and overheat while you are watching movies or playing games.
4GB RAM + 64GB ROM
4GB RAM + 64GB ROM storage memory allows you to display HD video smoothly and download massive resources from the Internet, it is enough to store large numbers of movies and Applications and browse the web etc.
2.4GHz + 5.8GHz Wifi
Dual-band dual WiFi connectivity for efficient, stable data and video output on your device 24/7. 2.4G plus 5.8G dual-WiFi and 1000Mbps LAN run internet, streaming, and audio perfectly without jerking, which allows you to play 4K @ 60fps, 3D, and H.256 videos smoothly.
Android 9.0 OS
Running on Android 9.0 operation system for strong compatibility, it is compatible with more software, games, and applications to improve user experience.
2.4G Voice Remote Control
Just speak to the 2.4G voice remote control, and it will operate the TV box based on your demand, such as the best action movies, today's weather, or the latest news.
Support 4K 60fps Resolution
Support multi-video decoder up to 4Kx2K @ 60fps + 1x1080P @ 60fps, which provides much more detailed and better-looking image.
Unique Skull Design
Geekbuying
249.99 after coupon: 4AINDUJC
More information
HERE > https://forum.freaktab.com/forum/tv-...g-x#post805175
