"uboot/partition bootloader/verify partition/error result" error @ 98%
    Having issues with my device. Wanting to get a custom rom on it. I have managed to to install one custom rom, but the box stopped being recognised in windows. I had to open it and use the pin shorting method.
    Now when I try and flash the device with a rom it gets to 98% and displays the following error:
    I've done some googling and some say use the SD card method. But my device won't boot into the android setup method. I've also seen the method of refreshing, but this doesn't work either.
    Any other advice???
    Neil
    I kind of solved this myself. I’m presuming the firmware/rom isn’t compatible with my device. As I am able to put Android 7 builds on, just not the custom roms
