X99 MAX-922 Amlogic S922X 4G/128G Dolby Atoms DTS Dual WiFi BT 5.0 Gigt LAN Optical USB3.0
    X99 MAX-922 Amlogic S922X 4G DDR4 RAM 128G 4K Dolby Atoms DTS 2.4G+5G WIFI Bluetooth 5.0 Gigabit LAN SPIDF USB3
    The X99 Max Smart Box is powered by the Amlogic S922X SoC, with 4 ARM Cortex-A73 processors capable of reaching 1.8Ghz + 2 ARM Cortex-A53 processors that reach 1.9Ghz.
    The GPU is an ARM Mali-G52 MP6 which expedites powerful games like PUBG. At VPU level we have the Amlogic Video Engine processor with HDR, Dolby Vision, Advanced HDR10, HDR10 + support, etc.
    4GB of LPDDR4 RAM and 128GB of eMMc storage expandable thanks to a microSD card reader that we have on one side if you don’t have enough.
    As for wireless connectivity, the X99 Max supports WiFi aC and Bluetooth 5.0 with internal antenna. At the interface level , it is dotted with USB 3.0 port, another USB 2.0, Gigabit Ethernet connector, SPDIF digital audio output, an HDMI 2.1 and a 3.5mm jack of analog audio and video output on the perimeter of the quadrangular box.
    Specification as found
    Model: X99 MAX-922
    Type: TV Box
    GPU: Arm Mali-G52 MP6
    System: Android 9.0
    CPU: Amlogic S922X
    Core: Hexa Core
    RAM: 4GB
    RAM Type: LPDDR4
    ROM: 128GB eMMC
    Maximum External Hard Drives Capacity: 4TB
    Color: Black
    Decoder Format: H.263, H.264, H.265, HD MPEG4
    Audio format: AVI, DAT, ISO, MKV, MP4, MPEG, RM, WMV
    Video format: AVI, DAT, ISO, MKV, MP4, MPEG, RM, WMV
    Photo Format: BMP, GIF, JPEG, JPG, PNG, TIFF
    Support 5.1 Surround Sound Output: Yes
    5G WiFi: Yes
    WIFI: 802.11 a/b/g/n/ac
    Bluetooth: Bluetooth 5.0
    Power Supply: Charge Adapter
    Interface: CVBS/L/R,DC ,HDMI,LAN,Micro SD Card Slot,USB2.0,USB3.0
    Language: Multilanguage
    HDMI Version: 2.1
    Other Functions: 3D Games,Others
    HDMI Function: HDCP
    Power Consumption.: 8W
    RJ45 Port Speed: 1000Mbps
    Power Type: External Power Adapter Mode
    Power Input Vol: 5V/2A
    Power Adapter Input: 100-240V / 50-60Hz
    Product weight: 0.2800 kg
    Package weight: 0.410 kg
    Product size (L x W x H): 11.40 x 11.40 x 1.8 cm
    Package size (L x W x H): 16.00 x 15.80 x 6.70 cm
    Package Contents: 1 x TV Box, 1 x Remote Control, 1 x HDMI Cable, 1 x Power Adapter, 1 x English Manual
    GeekBuying
