Virtually VMs
Hi Linuxium,
Saw your post. Have to say that this mini's aren't that mini. Indeed if they are able to run a VM even without a real hypervisor but inside a "sandbox" that's really a great way to improve the usage, because we can think that it may be possible to use x86 app inside that or notI help with 4GD663269M466950W
And you ????
My devices:
Tronsmart T428 real 3188 with Finless A928 and D33 Kernel at 720p
Tronsmart Prometheus won on CNX just now....
Hello Ian,
I have posted this to Google+ post, but get no reply from you, so add the same comment here:
I've tried to flash this kernel, but all I can get is kernel panic. I finally got 16GB model, so I have flashed 1.24 bootloader and used boot, properties, kernel and ubuntu rfs from your post ( http://www.freaktab.com/showthread.p...K802IV-or-T428 ). WIth the kernel in that post everything boots fine, but with the one (strange it has "recovery" word in its name [linuxium-lxc-recovery.img]) all I can get is kernel panic. USB is not loaded, so I am not able to pause to see more detailed message, it restarts quickly and gets in load-panic loop. Is there something else needed here? Or is the kernel image linked in here wrong?
There are currently 3021 users online. 1 members and 3020 guests.
