TX6 2GB/16GB Firmware needed
Originally posted by PedroHque122 View PostHi guys. I need the TX6 firmware 2GB RAM / 16GB ROM. In Brazil, TX6 is sold with 2GB / 16GB and without root access. I would like you to help me find the rom with android 7 or android 9. Thank you for your attention. I'm using a translator.
please no double Threads , further good luck to find your Rom ,
greetings / gefattern
I downloaded this firmware, however, I would like to make a backup of the current rom to avoid losing the TV box, since the website shows that the rom is for 4/32. I would also like to install android 7 because android 9 is slow. Can you tell me if there is android 7 for TX6 2GB / 16GB? I appreciate it
Originally posted by PedroHque122 View PostI downloaded this firmware, however, I would like to make a backup of the current rom to avoid losing the TV box, since the website shows that the rom is for 4/32. I would also like to install android 7 because android 9 is slow. Can you tell me if there is android 7 for TX6 2GB / 16GB? I appreciate it
Originally posted by PedroHque122 View PostYou can took me how install? I font know. And thanks for you help
i deleted the other Thread again , please stay with your Box Problems in this Thread , no need to always
make a new Thread , okay ??? , if this Rom not supports the your Wifichip , it will not work , so you need
a Rom with the correct Wifisupport , remember this , you can find several flash guides if you search for :
"Allwinner H6 flashing guide" , Pictures of Box and PCB both sides would be good too , so other Users
better can help , or find Infos ,
good luck / gefattern
HI ,
Originally posted by PedroHque122 View Postdo you mean that this rom can prevent my wifi from working? In this case. I will use network cable.
only if another Wifichip is supported in Rom , not sure if your Box used different Chips in the same
Production line , this often happens with cheap Boxes , you only can try , always your decision ,
do not always make new Threads and ask for Firmware , stay here in this Thread & wait & search & learn ,
otherwise we must BANN you for 2 Weeks or longer , because you not listen , understand it now ,
gefattern
Ok
please understand , it is better if you search & read all the Allwinner H6 Threads for better understanding ,
how to , or find a working Rom , Pictures of your PCB , both sides , would be good too , remember , this
cheap Boxes are not supported with Updates or new Roms , next time buy a better supported Box , like
Ugoos , Beelink or similar , or Amlogic Boxes there are several CustomRoms for there CPUs , but before
always look for your needs , because for Netlix and others you need DRM L1 , to use it in HD or higher ,
post some Pictures of PCB and look what Wifichip is used , so you can find the correct Rom better and
others can help better , be patient , i be sure your Box will get the right Rom ,
There are currently 2339 users online. 0 members and 2339 guests.
