Switching the box on for the first time, and the box is stuck on logo “ A95X “ The recovery mode shows that the software is Droid/ampere/ampere etc etc
Seller sent me a recovery rom. It’s the 309, intended for the Air model . Mine is RGB . The software is A95X F3 -S905X3-D3X4.zip
It worked ok for a few hours without any apps installed, but, “ mobdro” and “ cloudtv pro “ were included with the firmware
uninstalling “ mobdro” , and “ cloud tv” fixed problems when entering settings.
But, when the box was switched off and on again, it failed again.
Leaving the rom installed, I switched on the box, with a burned SD card , burnt with the same firmware, and pressing the usual AV recovery switch . As soon as I could see the robot at start up, I released the switch, and the box was working ok, only to find that it was now, overheating !
Next switch on, failed again.
There are scores of variants of this software , but , apparently, none is ideal for the RGB version.
I am suspecting that my box is actually an F2 not F3, because the only firmware, available, specifically for the RGB model is for the F2 box.
I have seen seen scores of complaints about this box, and it’s variants, AIR, Slim etc etc.
this is an eye opener for would be buyers
good luck
