Install on your T95MAX or any box Allwinner H6 the rom of Pendoo X6 Pro
LINK https://drive.google.com/file/d/11_T...ew?usp=sharing
then flash it with PhoenixUSBPro PC Tool and connect the tv box to ethernet or wifi at first boot
In Display settings set the correct resolution for your TV, now must delete some files and folders with the help of titanium backup and of a root browser. This step is very important because the space on system is limited and, if you don t delete all unnecessary files, you will receive an error of no space left on device when will push in the system the files of ATV9.
With titanium backup delete the app called Google 9.94.5.21 arm
Delete also one to one all preinstalled apps from settings apps except Airplay and disable app called simply Google
Now with a root browser/explorer in data/app delete the folder called com.android.vendingXXX if exists
In system, delete with a root explorer the entire folder called fastpreinstall and all files in preinstall folder except DairScreen
delete in system/priv-app the folders called GmsCoreSetupPrebuilt and PhoneSky
delete in system/app the folders called lcx6pro and YoutubeTV2
Now, without reboot the box, open from a pc - located in the same network of the tv box - the file in this folder called cmd-here and give these commands one to one
adb connect IP ADDRESS OF YOUR TV BOX
adb root
again...adb connect IP ADDRESS OF YOUR TV BOX
adb remount
adb push app /system/
adb push etc /system/
adb push framework /system/
adb push priv-app /system/
adb push usr /system/
adb reboot
Enjoy Android 9 ATV!!!
NOTE 1 - I tried in every mode to include playstore of all the versions for android TV but always says that the device is incompatible or crash. For this reason i have insert stock google service that obviously not working in ATV but you can use Aurora Store or other markets for download all the apps that you want spoofing another device, work also apps in ATV format not only the normals.
NOTE 2 - The procedure flash the files of keylayout of T95MAX, then will work only the stock remote infrared of the T95MAX. If you have another device, use another remote controller with a dongle USB or, if you want use the stock remote, copy and substitute - with a root file browser- the folder keylayout located in /usr with that of your stock rom.
NOTE 3 - At every boot will request a prompt where you must decide what launcher use..ignore it clicking on anything of they and will start ATV 9!
NOTE 4 - If at first boot of ATV9 you receive errors of crash of system apps unnecessary as Keychain, please ignore it, you can disable it but the errors should disappear alone in few minutes and not return.
Thats all!
UPDATE - IF YOU WANT ENABLE CHROMECAST INSTALL THIS APK OF CASTRECEIVER
FILES ATV9 https://drive.google.com/file/d/1w1uBtPgHkk_jhvjSHuLzUKGYfjkNmPyE/view?usp=sharing
SCREENSHOT https://imgur.com/a/VrCx2Gp
VIDEO https://www.youtube.com/watch?v=GEMATh0fYkU
