Many thanks
T95 Max Help,
T95 Max Help,
Hi there, Im new to the forum, great site by the way, Ive bought the T95 Max as an IPTV player only so I would like to install a stripped back firmware so there isnt loads of stuff I dont need clogging it up, can anyone suggest something and also an idiot proof guide.
Many thanksTags: None
Guest
I made the first Android TV 7 port rom for our T95MAX, but I think it should works well on any Allwinner H6. I have entered a big number of optimizations for the processor, there is also Magisk, but it does not work, even if there is a classic root and Youtube and many others apps work at 1080p. Otherwise, everything seems to
Well, its time of Android TV 9 for all AllWinner H6!!! Install on your T95MAX or any box Allwinner H6 the rom of Pendoo X6 Pro LINK https://drive.google.com/file/d/11_T...ew?usp=sharing (https://drive.google.com/file/d/11_TqTWv2hjlHEiceNHtG87TTEod3nOTr/view?usp=sharing) then flash it with PhoenixUSBPro PC Tool and connect
There are currently 2130 users online. 5 members and 2125 guests.
