need a help for android tv 7.1.2
Originally posted by mAtvXk View Post
ATV Launcher (PRO) ;-)
and i want to make atv launcher pro as default
Knowing that I selected it by default in the parameters
how can i solve this problem please ?
Originally posted by kivomoh605 View Post
I tested the launcher its perfect but when I press the home button it goes to the default launcher
not much , without "root" , for this you must change your "keyfile" string for the Homebutton ,
you only can use the "back" Button then ,
as you set it as default in Settings , it must start after reboot direct in the right Launcher ,
greetings/ gefattern
Hi ,
There are currently 3938 users online. 0 members and 3938 guests.
