Beelink GS-King X S922X-H 4GB/64GB 4K 60fps TV Box Supports 2*3.5 inch HDD
    Beelink GS-King X S922X-H 4GB DDR4/64GB eMMC 4K 60fps TV Box Supports 2*3.5 inch HDD NAS dolby DTS Android 9.0 2.4G+5.8G WIFI Gigabit LAN
    Make Your Home A Cinema
    Beelink GS-King X adopts the latest Amlogic S922X-H chip (Quad-core Cortex-A73 @ 2.2 GHz + Dual-core Cortex-A53 @ 1.8 GHz), which is the strongest chip in TV box at present. This TV box features high-end Hi-Fi lossless sound quality and Dolby sound effects to give you an immersive hearing and viewing experience, which is one of the most cost-effective products.
    DTS Listen + Dolby Audio
    Beelink GS-King X features DTS listen + Dolby audio decoding, offering Hi-Fi losses sound quality to you for an immersive experience.
    Amlogic S922X-H Hexa-core CPU + Hexa-core ARM G52 MP6 GPU
    With the high-performance CPU + GPU, making the GT-King Pro TV box runs fast and smoothly with excellent heat-dissipation, never worry about buffering and overheat while you are watching movies or playing games.
    4GB RAM + 64GB ROM
    4GB RAM + 64GB ROM storage memory allows you to display HD video smoothly and download massive resources from the Internet, it is enough to store large numbers of movies and Applications and browse the web etc.
    2.4GHz + 5.8GHz Wifi
    Dual-band dual WiFi connectivity for efficient, stable data and video output on your device 24/7. 2.4G plus 5.8G dual-WiFi and 1000Mbps LAN run internet, streaming, and audio perfectly without jerking, which allows you to play 4K @ 60fps, 3D, and H.256 videos smoothly.
    Android 9.0 OS
    Running on Android 9.0 operation system for strong compatibility, it is compatible with more software, games, and applications to improve user experience.
    2.4G Voice Remote Control
    Just speak to the 2.4G voice remote control, and it will operate the TV box based on your demand, such as the best action movies, today's weather, or the latest news.
    Support 4K 60fps Resolution
    Support multi-video decoder up to 4Kx2K @ 60fps + 1x1080P @ 60fps, which provides much more detailed and better-looking image.
    Unique Skull Design
    With the design of the skull pattern style, it is also an exquisite ornament when you place the equipment for your bedroom, sitting room.
    Learn more here.
    $239.99 after coupon: GSKINGX for Beelink GS-King X
