I need some Stock ROM and custom ROM for this TVBOX, Chip H3 Winner, anyone can help me?
I need ROM for MXQ PRO 4K
trash it , why are all buying this MXQ Shit , it is 5 Years old , or similar ,
for sure we need more Info , because this shitty PCBs use always
different Wifichips , buy a new one , not this cheap MXQ Shit , this only
makes this non supporting Manufactors rich ,
further good luck / gefattern
How do you know he bough it?
Maybe it was given to him or some one wants to fix it and install taco bell apps on it instead of his phone?
Ill help you look, you can try here https://forum.freaktab.com/forum/mai...ge-many-models
Im sure there is a file out there gona have to dig
Originally posted by larrywilson View Post
Anyone know how to make Generic Usb Joystick work? This box cannot recognize my Joystick, but usb or wireless mouse still work
I have 2 that work on my MX10 pro which is simmilar has 3 USB on the side and one USB3 in th eback no bluetooth
I used a PS3 clone controller that works on an older bluetooth $17.99 comes with a USB charge cable that i can plug directly to the TV box and it works like a wired controller
The second one is a 2.4G wireless that comes with a little dongle and works kinda like a wireless mini keyboard, IMO they both work about the same, the PS3 jamswall feels a little better in the hand then the 2.4G one
KInda weird, the wired one works on th ebox without bluetooth but i couldnt get it to work on any of the other boxes i have with a working bluetooth. The 2.4G one with the dongle thing is just instant plug and play and ive used it on every box i have without any issues.
Both are $17.99 on Amazon, the 2.4G uses 2 AA batteries the PS3 one uses a rechargable battery but when wired it doesnt matter. Im not sure what bluetooth version the PS3 one uses but i couldnt get it to link to anything so its a dedicated controller for the non bluetooth boxes i have
On another note ive bought like 4 of those cheaper "Bluetooth" dongles off the bay and none of them would work, they must need a driver to work or something, why the 2.4G controller works and a bluetooth dongle doesnt is beyond me
Even the 3 wireless keyboards and air mouse controller i have are plug and play and they all work instantly but the bluetooth is hit or miss if it will which i dont understand
processor allwinner H3 1.01 GHz
android version 8.1
architecture 4x ARM Cortex-A7 @1.01GHz
Revision r0p5
clock speed 480MHz-1.01 GHz
gpu vendor ARM
gpu render Mali-400 MP
model : dolphin (dolphin_fvd_p1)
manufacturer Allwinner
Board exdroid
Hardware sun8iw7p1
total ram 1024 MB
internal Storage 8.00GB
bootloader unknown
Build ID dolphin_fvd_p1-eng 8.1 NRD91N 20191122 test-keys
kernel version armv71
Wifi SV6256P (2.4.ghz , 5ghz )
hope this would help
Originally posted by nomadtamad View Postprocessor allwinner H3 1.01 GHz
android version 8.1
Revision r0p5
gpu vendor ARM
Board exdroid
Hardware sun8iw7p1
total ram 1024 MB
bootloader unknown
I have same problem... Problem is solved by backup original rom from working box.
Steps that i made is:
-Flash box with this firmware using phoenix suite:
https://mega.nz/#!I9oFBISb!8ozfiBuxs...GR2Db55AA-03P0
Box boot, but with not working wifi.
-Go and activate developer options and enable usb debugging.Check USB0 device mode enable
-Copy twrp.zip (from archive in link bellow) to flash drive
-Connect phoenix suite to box and press recovery.Box will boot into recovery mode
-Press install update from external and choose twrp.zip (executable only) DO NOT TRY to install, just run it!
-Make full backup of "no-wifi" rom (check all boxes) and save it to external flash drive
-When is done, disconnect flash drive from box and connect to pc. Replace only files ( from backup in link bellow ) to folder in flash drive. DO NOT rename folder!
-Boot box to "no-wifi" rom and connect to phoenix suite, press recovery again.
- From stock recovery load twrp.zip again, point where backup is, mark again all boxes, and choose restore.
- Wait to finish and press reboot when is done. Box will boot to stock firmware with working wi-fi ...
Link to backup with all needed files:
https://mega.nz/file/1kd0ATRR#IDU0a8...Lje8BBGx4uidvw
Good luck to all!
There are currently 2286 users online. 10 members and 2276 guests.
