Boot animation not working - HELP NEEDED.
    Hey!
    I looked everywhere online! my Boot animation is just not working and i swear i've tried everything
    Things I've tried:
    - compress using "store" method winrar
    - installed boot animation software - doesn't work
    - Pressed enter at the last line in the desc.txt (Read that somewhere)
    - I tried changing the file names
    If anyone could help that would be super helpful!
    If your rooted, I believe you can copy a boot animation to your device> system> media folder. "bootanimation.zip", it would need to have proper R/W file permissions applied.
    Not to sure...also a chance to boot loop your device if you mess with the system files.
    Possibly, boot animation can also be turned off/on in the Build.prop file
    service.bootvideo=1
    (there is another option(?) for fast boot that disables bootanimation...I think)
    For creating your own boot animation, this link may help:
    The boot animation is the first thing that you see when powering on your Android phone or tablet, after the operator or manufacturer logo. Although it
    ****Make a TWRP backup, to SD card, of your system before messing with any system files. ****
      same here....not showing up..
      Before it was bootvideo. I deleted and set to service.bootvideo=1, put bootanimation.zip to system\media, vendor\media and another media dir...not wrórking
        Got IT!!!!!
        Howto:
        System\etc\init\bootanim.rc
        service bootanim /system/bin/bootanimation
        class core animation
        user graphics
        group graphics audio input
        enabled
        oneshot
        writepid /dev/stune/top-app/tasks
