Please, help me with it!
What model of this?
Originally posted by angelusinferni View PostI can't change the firmware of the card because I can't even find the place to close the short.
look second Picture , above the Heatsink , left corner , this is the Nand , look for a small triangle /pyramide ,
from there count to pin 7&8 , this two pins normal must work to short ,
good luck / gefattern
Hi ,
I already tried with these 2 roms and I was not successful with any of them.
first , please do not flash every stupid same SOC Rom to your PCB , it is better to search a little bit
more , for sure it must fit with your Wifichip , what AndroidVersion was installed before ??? , are you
sure it is a RK3229 Box or not 3318 or similar , they use different SOCs & Chips for this cheap Boxes ,
if you want good streaming & Movie things , to buy a MiBox / FireTV or similar well supported Box ,
same price then this shitty cheap Boxes , if ChinaBoxes , Ugoos & maybe Beelink are the best Rom
supported Boxes ,
PS : better to use AndroidTool above 2.38 & latest RKDrivers above 4.4
Hi ,
supported Boxes ,
Your patience with posts/threads like these is almost infinite...
Hats off to you .
Angelu
RK 322A ....... in Batch tool
Yikes clone of a clone of a clone
Try entertainmentbox.... for firmware for nexbox rk3229
You will need original stock for any chance at recover
Probs 5.1.1 or 6.0
Hello, I am currently working on 2 MBOX MXQ Pro 4k. These things are junk from china. They have the RK3229 SOC as well. They RK3229 itself isn't so bad a chip. But the rest of the box is about 12 cents. I have one in factory condition as I have been trying to get a decent clone of it. They are almost impossible to brick. Things get a bit messy when you wipe the bootloader thought. It put it in maskmode and they aren't always the easiest to get going again.
Hi ,
supported Boxes ,
I was unable to unlock the device to install a linux system.
and I couldn't understand this triangle or pyramid referent.
there's nothing with that shape on the board.
sorry for the delay to answer, and I put in the s905x because the a95x are normally s905x.
I can't even find a manual for that card to know the exact point of the short to remove this firmware block from the device.
sorry for my english,i'm used google translate.
on the plate is written "mini tv box RK3226_D16" REV1.2 and the only component with identification is the one in the upper left corner of image 2 (essencore I3T-8GQ8T2H5TARC) whenever I look for that piece the search results are always for tvbox a95x .
This is a triangle / pyramide , please look my next Post ,
do you understand it now ????
it mostly has the colour " white"
you mean RK3229 or not , not 6 ????
greetings / gefattern
Originally posted by gefattern View PostHi ,
but some PCB do not have any sign , you can try it from both sides ,
it can not bricked much more , pin 7&8 ,
please can you confirm me if it is one of those that i made an outline?
where it’s circled in green I’ve already tried pins 7 and 8 on 2 sides but didn’t get any results.
my device tries to boot the sdcard with the respeaker but the answer that the device is that it was not possible to boot the sdcard
There are currently 1476 users online. 0 members and 1476 guests.
