The 96X Max- does not do 8k nor 4k. It goes up to 1080. The native remote does not work. Speed is very low, similar to my old Orange Pi H3 machine. Is it really an S905x3 machine !
S905x3 - oH96x Max vs A95X
The A95x is very fast, but, so far, there is no stable firmware. Apparently, the issue is in the video resolution . I had to return the box, because, after an online update, the box failed, with a black screen.
The 96X Max- does not do 8k nor 4k. It goes up to 1080. The native remote does not work. Speed is very low, similar to my old Orange Pi H3 machine. Is it really an S905x3 machine !Tags: None
If a box has S905X3 then it will do 4K,so i don't know where you get the 1080p limit from.
You have mentioned a oH96x Max and 96X Max-, neither of which I recognise, so I'm guessing these are typos?
8K is nothing but a marketing gimmick so I would not personally give it a second thought right now.
Originally posted by bluesmanuk View PostIf a box has S905X3 then it will do 4K,so i don't know where you get the 1080p limit from.
There are currently 1910 users online. 1 members and 1909 guests.
