Prepare idb fail T9 4GB/64GB TV BOX (RK3328)
I have a T9 4GB/64GB TV BOX (RK3328) TV stick, it got bricked. I searched the internet and tried many methods to recover it, but failed, please help if you know a better solution. I used RKBatchTool to restore it, and got a blue square, but after I click "restore" button, it failed at "Prepare idb fail" I also tried RK Android Tool, my stick is loaded as "Found one MASKROM Device". I played around the tool, but every time it failed at the same reason "Prepare idb fail ". I have no ideas, anyone please help!Tags: None
Originally posted by billi69 View PostI have a T9 4GB/64GB TV BOX (RK3328) TV stick, it got bricked. I searched the internet and tried many methods to recover it, but failed, please help if you know a better solution. I used RKBatchTool to restore it, and got a blue square, but after I click "restore" button, it failed at "Prepare idb fail" I also tried RK Android Tool, my stick is loaded as "Found one MASKROM Device". I played around the tool, but every time it failed at the same reason "Prepare idb fail ". I have no ideas, anyone please help!
this is a stupid Brick , there is only one Way to restore :
https://forum.freaktab.com/forum/tv-...for-rk-devices
hope you get it , best to restore with Stockrom ,
good luck / gefattern
Hi ,
Same issue
Same issue
first , listen , no need to always make a new Thread with the same Problem , stay here ,
we not need different Threads with the same Problem of you , understand it please ,
stay here , here try this Tools :
Archive.zip
with DevTool you can try to flash bootloader and test your boot sectors , the other is for
the SDCard flash/restore , most after this kind of brick the Boxes only can be used for
boot a System from SDCard , if there would be a Tutorial here ,
good luck / gefatternAttached Files
Guest
Originally posted by Bloem View PostI have the same problem, I tried all the methods and searched the internet and this strange problem was not solved, there is no solution to this problem !?...
There are currently 1256 users online. 0 members and 1256 guests.
