[HELP] thl Super Box S912
    Hi
    I have a problèm with my thl Super Box
    The original firmware is work but Android 6
    I tested firmware android 7 -9 is work too but Lan not working juste wifi ok
    Can you help
    Original firmware here
    https://mega.nz/file/FQMWmICY#Y7iE_j...6Z6dAHbEh2RRb8
    i think just problem driver l'an
    photo of mothboard
    https://www.ixbt.com/live/uploads/im...c05766990b.jpg
    https://www.ixbt.com/live/uploads/im...1c74ec90aa.jpg
    https://www.ixbt.com/live/uploads/im...729ca0fbc2.jpg
    https://www.ixbt.com/live/uploads/im...4bc18ff4ea.jpg
    Thnks
    I finally found the solution. ATV 9
    Everything works for thl Super Box and excelvan ex - t2 tv
    Change language after installation or Checked " Reset after succèss in usb burning tool
    rom Android Tv pie 9
    https://drive.google.com/file/d/1SBe...cbAQ0yr-R/view
    THL is a brand whose acronym means Technology Happy Life, is a Chinese company that has contributed in the technology market with smartphones of excellent quality as for example the THL Knight 2, filling our daily life of innovation and following this concept has decided to expand its range of items to our homes, featuring the THL Super Box, a Tv Box that comes to entertain us in any corner of the world and also has an amazing design, full of phenomenal features, which promises to meet our entertainment requirements.
    Not so Happy... EOL as soon as it headed out the door?
    * Possibly similar to X92 with 2g of ram?
    Ugoos AM3 ( less likely?)
    * Find a mod of either one's firmware.
    * generic AtvXperience v2FF(DDR/LPDDR) or V2E ?
    *Mod with ice_tx92_20180526_to_X98pro (X92) _2_16_3_16 (4PDA)
      yes i tested atvxperience and others. All ok but lan not work
        • Try changing your network cable, might be damage.
        • Check the port on China Box, they can get corrosion...
        • Check router, make sure mac address in not limited or blocked?
        Stick to WIFI if all else fails. Some connection is better than no connection.
          all work in others box
          the problem is l'an driver
          i home found the solution bcs i like internet with lan. Wifi many problèmes
          thanks
            ROM] "Generic" SC ATV v1.0 USER/USERDEBUG - S912 Pie - Multi-Wifi BCMBT/QCABT work for me with 100MBITS-ETH-FIX-FLASHABLE-ZIP
            but remote not work lol
              ** Did you for Android 7:**
              1. Turn off WIFI
              2. Attach cable.
              3. Reboot
              4. Verify the WIFI is still off.
                1. Turn off WIFI
                2. Attach cable.
                3. Reboot
                but i test all possibility
                now all work with patch for 100mb but remote not ok
                i tested atvexperience with patch but not boot after update
                i search egain
                    Hi
                    with my vorke z6 plus
                    I installed [v7] Aidan's ROM [S912] [ATV 9] [LPDDR3] which has the latest android tv launcher etc... but some issues that I need help because
                    1 - It doesn't transfer the sound to headphone by bluetooth; indeed the rom find the headphone by bluetooth, it is associated and connected but no sound from my headset
                    2- the cursor of my remote or my remote is not fully compatible with the rom, how to fix the remote control or do I need to buy a new one and which one?
                    3- how to install Twrp recovery and root those atv rom because I need to patch display led in this atv rom
                    NB: this post and previous one are the same, I need a android tv rom for my vorke z6 plus which has led display patched, bluetooth and latest google play store, chrome and android home
                    thank
