Beelink GT-R Barebone MINI PC 16 GB DDR4 512 GB SSD 1 TB HDD AMD Ryzen5 3550H Radeon Vega 8
    The Beelink GT-R comes in a barebones model without RAM and storage, as well as models that come with 256 or 512 GB NVMe SSDs. Users can add up to 32 GB of RAM and the PCIe 3.0 X4 NVMe storage solution can be complemented with an additional M.2 2280 SATA 3 module, plus a 2.5-inch unit.
    It is equipped with the Ryzen 5 3550H quad-core / eight-thread CPU which combines four Zen+ cores (8 threads) clocked at 2.1 - 3.7 GHz with a Radeon RX Vega 8 graphics card with 8 CUs (512 Shaders) clocked at up to 1400 MHz. The integrated Vega 8 GPU can easily handle all four video outputs provided, of which two are HDMI, one is DisplayPort and the other USB-C 3.1 connector that can work as DisplayPort. Port selection also includes six more USB-A 3.0 connectors, a headphone jack and two GbE jacks coupled with Wi-Fi 5. There also is a dual-array mic.
    One special feature that is rarely seen on mini PCs is the fingerprint reader placed on the upper lid. With the included software, users can set up fingerprint-secured logins, as well and encrypt important files.
    Code:
    [B]Specification[/B]
    [TABLE="border: 1, cellpadding: 5, cellspacing: 0"]
    [TR]
    [TD]General[/TD]
     			[TD]Brand: Beelink
    			Model: GT-R
    			Type: Mini PC[/TD]
     		[/TR]
    [TR]
    [TD]Hardware[/TD]
     			[TD]OS: Windows 10
    			CPU: AMD Ryzen5 3550H,4 Cores 8 Threads 2.1Ghz,UP TO 3.7Ghz,Cache 6MB
    			Instruction Set: 64bit
    			Lithography: 12nm
    			Graphics: Radeon™ Vega 8 Graphics 1200 MHz
    			RAM: 16GB DDR4 ,Up to 32GB(Option)
    			SSD: 1x 512GB M.2 PCIE 4X SSD,1x M.2 SATA3 SSD Slot,1x 1TB 2.5inch SATA3 HDD[/TD]
     		[/TR]
    [TR]
    [TD]Communication[/TD]
     			[TD]WIFI: 2.4G/5G, 802.11 b/g/n/ac , MIMO
    			Bluetooth: Bluetooth4.2
    			LAN: 1000M[/TD]
     		[/TR]
    [TR]
    [TD]Media[/TD]
     			[TD]Decoder Format: H.264,H.265
    			Video format: 4K,4K x 2K,ASF,AVC,AVI,DAT,FLV,ISO,MP4,RM,RMVB,RV,TS,VOB,V P9,WMV
    			Audio format: AAC,AC3,ACC,APE,DDP,DTS,MKA,MP3,MPEG,OGA,OGG,RM,Tr ueHD,WAV,WMA
    			Photo Format: BMP,GIF,JPEG,JPG,PNG
    			Support 5.1 Surround Sound Output: Yes[/TD]
     		[/TR]
    [TR]
    [TD]Other Features[/TD]
     			[TD]Language: Multi-language
    			HDMI Function: HDCP[/TD]
     		[/TR]
    [TR]
    [TD]Interface[/TD]
     			[TD]Fingerprint recognition x1
    			PWR BTN x1
    			CLR CMOS BTN x1
    			DC JACK x1
    			USB3.0 x6
    			100/1000M RJ45 x2
    			HDMIx2 Standard HDMI Connector
    			DP x1
    			MIC x2(Built-in)
    			Audio Jackx1(HP&MIC)
    			Type-C(date/video) x1
    			Internal Connector
    			M.2 2280 SSD x2
    			SATA 3.0 HDD x1[/TD]
     		[/TR]
    [TR]
    [TD]Power[/TD]
     			[TD]Power Consumption: 19V/3A
    			Power Type: External Power Adapter
    			Power Supply: Charge Adapter
    			Certification: CE,FCC[/TD]
     		[/TR]
    [TR]
    [TD]Dimension&Weight[/TD]
     			[TD]Product weight: 0.753 kg
    			Package weight: 1.449 kg
    			Product size (L x W x H): 16.80 x 12.00 x 3.90 cm
    			Package size (L x W x H): 18.00 x 12.90 x 11.00 cm[/TD]
     		[/TR]
    [TR]
    [TD]Package Contents[/TD]
     			[TD]1x GT-R MINI PC
    			1x Wall mounted bracket
    			1x OS Disk(16GB U disk)
    			2x Hdmi cable
    			1x Power adapter
    			1x Power cable
    			1x User manual
    			1x Installation guide[/TD]
     		[/TR]
    [/TABLE]
