rooted tv box
tried holding reset button inside av port with toothpick but does not boot from sd card
os-------Armbian_20.02.0-rc1.037_Aml-s9xxx_bionic_current_5.5.0-rc6_desktop_20200205.img
Win32DiskImager-0.9.5-install
made bootable sd card
renamed dtp file to dtp.img
---------if i use this method to boot-is there any danger to my device ?
Connect the prepared media to the device and turn on the power, boot into Android
- Open the app "Update&Backup"
- Click on "Select" local update and chose the file on the removable media aml_autoscript.zip
- Start "Update"
- System will reboot twice and start running the system from external media.
