I'm a student and I work on a project that aims to use inexpensive android tv boxes as servers that could allow anyone within a wifi range to access local resources like Wikipedia or Khan academy for free - even in areas where the internet and electricity is unreliable.
I would like to know what would be the best box to run a server on what will use content on an SD card.
Ideally, I would like something that is
- affordable
- use common CPU and wifi drivers
- easy to root
- and can be used to create a captive portal (something like this)
Ok to be fair, I'm very new to this, but it's for a good cause.
You guys are better at this than me, I can tell already.
Any suggestions? I will name the first boxes we deploys in remove villages after you!
Thanks,
