Thx
Next 7D12F Specs
Originally posted by Viralata View PostHi, i have a NExt 7D12 (without the F) and want to check if it is compatible with the rom for the Next7D12F. Can someone psot the info of CPU-Z to check the compatibility ?
Thx
The Next7D12F used a RockChip based board. All of the newer Nextbook models use Amlogic based boards.
I recently recieved a system dump from a Next7D12R that uses Amlogic.
Have you managed to root your tablet? If not, people have been having success with Cydia Impactor on all the newer Nextbook models.
If you can root it, I can help you dump the firmware so that I can create a stock ROM, and eventually a custom ROM for your model.
ShaunMTFreaktab Rom Developer
Originally posted by Viralata View PostYes i rooted my Tablet =D, i believe the board its the same, but i know more of PC hardware than Tablets...
How i dump the firmware ?
The ROM have some annoying bugs that i would like to fix.
Sorry my bad english ^^
Thx =DDD
The easiest way to get the system partition is to use Onandroid (Online Nandroid Backup) from the play store to create a backup. It grabs some of the other partitions as well, but not all of them.
The only way to get all of the others is to dd them. (You can't just DD system too because it is ubifs.)
Here is how use dd to dump partitions:
Do
Code:cat proc/mtd
You should get output something like this:
Code:dev: size erasesize name mtd0: 00800000 00200000 "bootloader" mtd1: 00800000 00200000 "logo" mtd2: 00800000 00200000 "aml_logo" mtd3: 00800000 00200000 "recovery" mtd4: 00800000 00200000 "boot" mtd5: 20000000 00200000 "system" mtd6: 00800000 00200000 "cache" mtd7: 40000000 00200000 "userdata" mtd8: 18c00000 00200000 "NFTL_Part"
Cache is user settings. Userdata is downloaded apps. System, cache and userdata can't be backed up properly using dd. Use Onandroid (Online Nandroid Backup) from the play store.
Don't mess with NFTL_Part!
Output file names should be as follows:
"bootloader" = bootloader.img
"logo" = logo.img
"aml_logo" = aml_logo.img
"recovery" = recovery.img
"boot" = boot.img
So your command lines for dumping should be in this format:
dd if=/dev/mtd/mtd# of=/sdcard/external_sdcard/ouputfilename
Check your mtd#'s on your device using cat proc/mtd and fill in the mtd#'s and output file #'s and enter the dd commands one line at a time.
If your cat proc/mtd output matches my device, then your lines would be:
Code:dd if=/dev/mtd/mtd0 of=/sdcard/external_sdcard/bootloader.img dd if=/dev/mtd/mtd1 of=/sdcard/external_sdcard/logo.img dd if=/dev/mtd/mtd2 of=/sdcard/external_sdcard/aml_logo.img dd if=/dev/mtd/mtd3 of=/sdcard/external_sdcard/recovery.img dd if=/dev/mtd/mtd4 of=/sdcard/external_sdcard/boot.img
When done, copy the files and folders you dumped off your external sd card, zip them all up together in a single zip file, upload them and let me know where I can download them.
Originally posted by tony763 View PostHi, can somebody of you make a dump of NEXT7D12R, please?
There are currently 1893 users online. 2 members and 1891 guests.
