Nexon X8 Amlogic s905x3 4gb/64gb
Box looks like the X96_Max+ with S905X3, try this firmware:
https://www.evolutiontv-vs.com/uncat...%be%d0%b2.html
UBT does not detect a prefix.Didn't know that it was so difficult with a S905x3.I once stitched it with GT1mini-2_v204P0.img.It is normal but does not turn on afterwards.
2020.08.01-09.txt
After that I made my own firmware from this firmware and a backup of my firmware.I stitched this homemade firmware.
2020.08.03-18.txt
With a mistake.Perhaps I did the wrong firmware.Now the prefix is not detected with UBT.
There are dots on the board RX TX GND .I will try using uart adapter.It's not urgent for me.I still have another console working.I found out the manufacturer by MAC address.https://fccid.io/2AI6DShenzhen Amediatech Tech Co, Ltd But they didn't give me the firmware.Contact Email: [email protected]
If memory is correct that Amediatech Tech Co. is in fact the OEM of the X96 Max/Max+, believe I saw the name when the DTB was added to Linux mainline a couple of update cycles previously for the S905X2 board.
Did you try Vasily's ROM from link above? Can watch video : https://forum.freaktab.com/forum/tv-...881#post811881
Believe the MaskROM reset pins are Round Circle contact points near the eMMC chip.
Originally posted by RiCkLaR_atvX View PostIf memory is correct that Amediatech Tech Co. is in fact the OEM of the X96 Max/Max+, believe I saw the name when the DTB was added to Linux mainline a couple of update cycles previously for the S905X2 board.
Originally posted by sagert View PostI restored the prefix by closing the contacts.Installed the firmware from H96 Max X3 Slimbox v7.WiFi does not work and does not show the front panel.But I have a backup of the old firmware.Just how can I change the files in the fiirrmware?
There are currently 918 users online. 0 members and 918 guests.
