Cant downgrade from 9.0 to 7.1.2,
Ahhhh
Entiendo
Ihave t95m have been testing s905X.....clone of clone i think
Try this Maybe
With Amlocic Tools create SD boot card
If you have 6.0 version in OTA format unzip and take u-boot bin file and place in SD Boot Card Maker and Create/Make
If success on the same SD card copy over the OTA 6.0(in needs to be in compressed format/do not unzip.
I have had sucess also by loading OTA file on USB thumbdrive to keep separate from SD Boot Card
When you boot to recovery select Update External it will search for the OTA file on SD card or Thumb Drive whereever you put it
Hmmmmmmmmmmmmm
Now iam No Comprendo
You post that all attempts to flash= stuck on boot logo
You post that you are familiar with Mask Rom Mode because you use that method to flash anything in 9.0 Rom?
It does not matter
You resolved the issuse yourself
You are back to 7.1.2
Probs more Stable for this CPU
Happy Testing
It does not matter
Happy Testing
There are currently 1463 users online. 2 members and 1461 guests.
