MXQ Pro RockChip Bricked - Need Help
I got a problem were the ROM was super heavy (in my case was 8.1). It was so heavy to the point the device after an hour or so would freeze or crash entirely. Until one crash brick my device.
Used the same process you did, and got a ROM 7.1.2. Seems lighter than the original, box doesn't get more than warm now, and after 3 days with my sons watching Youtube and Netflix for hours and hours, no crash. Still have my fingers crossed, but that is something you can look at.
My processor was RK3229 and my WiFi 6051p. I only now need to use remote control from another device but that is ok. The remote was not in use anyway since I can turn on and off the device in a different way.
But be aware, maybe try other ROMs till you find one that fits betters your device.
Need help for stock firmware (Motherboard was MXQ_W_EMCP_V1.2) +
How to Un-Brick this "MXQ PRO 4K 5G" Android TV Box??Last edited by _effendy; 05 March 2022, 23:18.
Originally posted by _effendy View PostNeed help..
[LIST][*]https://serving.photos.photobox.com/...b42ca40ec1.jpg
[ST]
How to Un-Brick this MXQ PRO 4K 5G Android TV Box??
This is Amlogic S905W
You are in Rockchip Based TV Box
Leave here
Move to Amlogic S905X
Sub Forum Other Amlogic S905X
Thread By alexxiss
!0,000 plus views
Discussion on this S905W CPU
Also in Firmware /Roms / Tools are other Threads with Discussion on Box
Good Luck
Happy Testing
I have MXQ Pro 5g 4k android. It came with Android11.1 4gb 32gb which I am sure are fake specifications. It was extremely slow and the internal storage setting was greyed meaning that you could not open it to explore it. Upon opening the case, I discovered it has an MXQPRO_V73 2021-06-19 board and an RK3128H processor under the heat sink. However, the CPUX app showed it has rk3066 and the recovery menu indicates it comes with RK322X. I can only connect it to the computer in maskrom mode and most of the RK3229 firmware ( loader v2.37) flash successfully but won't boot. Is the bootloader the problem? Any help will be highly appreciated
Originally posted by SSimon View PostI have MXQ Pro 5g 4k android. It came with Android11.1 4gb 32gb which I am sure are fake specifications. It was extremely slow and the internal storage setting was greyed meaning that you could not open it to explore it. Upon opening the case, I discovered it has an MXQPRO_V73 2021-06-19 board and an RK3128H processor under the heat sink. However, the CPUX app showed it has rk3066 and the recovery menu indicates it comes with RK322X. I can only connect it to the computer in maskrom mode and most of the RK3229 firmware ( loader v2.37) flash successfully but won't boot. Is the bootloader the problem? Any help will be highly appreciated
you need a Firmware , a search with your Boardnumber and Wifichip maybe helps , but i am sure
you will not find much for it , important is what your Stock Firmware shows in Flashtool , example ,
my Roms show 330A , it is a RK3399Box ,
maybe you can try this Links :
Pessoal minha tv box brickou, preciso dar um jumper na placa para reconhecer no PC e poder instalar outra firmware. Porém ja catei em tudo que é canto e não existe tutorial para essa placa. Alguém tem ideia onde posso fazer o jumper sem queimar a placa? vou pro tudo ou nada! modelo mxqpro v72
Boa tarde peguei um MXQ novo porém após meia hora inicializado começava reiniciar sozinho, achei que poderia ser temperatura, porém aparentemente temperatura estava normal, fui tentar usar outra room, porém usei umas 4 e nada . e ultima q tentei BRICKOU o aparelho, não achei essa placa em lugar n...
Link 1 / Post 15 / Link 2 / Post 9 , but the best would be to buy a better one , MXQ Boxes always traschy ,
by the Way CPUX always shows RK3066 ,
further good luck / gefattern
There are currently 3911 users online. 0 members and 3911 guests.
