Tanix TX6 Allwinner H6 WiFi bluetooth issue for 2020 TV box
    ??Dear freaks,
    I purchased a Tanix TX6 H6 box with android9 some weeks ago. I was trying to install the root management app and the device got bricked. Then i found the firmware from Tanix website and flashed with pehonix suit. After flashing the device got working but unfortunately WiFi bluetooth and spdif out are not working. The device is working with LAN and other things fine. The Wifi module comes in the board is RTL8822CS.
    In android settings the wifi MAC shows 02:00:00:00:00:00 and bluetooth address unavailable.
    Thinking that i have flashed an older firmware but the device board shows the year 2020 and the kernel is not supporting the wifi module.
    Is there any chance or any coding in dtb file that i can use for the integration and how can i do the edit in dtb file with rom in sd card?
    Is there any flashable zip update for the wifi module available or any 2020 firmware available?
    Does somebody facing the same issue??
    Please share any experience or any solution to solve this issue.....
    Also find attached pictures for details....
    Thanks and regards....
ID:	811807Click image for larger version
    Contact Tanix support and ask them to provide a specific firmware to you. ;-)
      Thank you very much bro! to provide the tanix support email. I was contacting tanix for any technical support but I couldn't. Anyway I will try.....!
        Look in the "Tanix TX6" forum thread, the firmware version from 20190722 was suppose to have all the different wifi drivers for the different TX6 boxes that are out there, and the only firmware that was newer than that one was for the Pendoo version of the TX6 which I have never tested, the 20190722 worked well enough for me.
          Thanks for the reply bro!
          I have already tried the one 20190722 but the same problem exists and the UI shows the device is not activated. Currently I loaded the pendoo firmware LC-X6PRO-4Gddr-20190819.img and still wifi-bluetooth and spdif out not working. I already sent emails to oranth but no reply. There may be an update package or driver package for my RTL8822CS wlan module because the other old boards having different modules loaded.
            anyone has a working link for "TX6_H6_8822-9_4Gddr_20190722.img"
              H6_9_4Gddr_20190722.img [MEGA.nz]
                Hello
                Did you find a solution with RTL8822CS ?
                I have exactly the same problem with TANIX TX6_H6_9_4Gddr_8822bs_20190228.img firmware and I cannot find the original firmware for my OEM TX6-H
                Possibly IMG_20201225_093503.img
                  it worked for me, thanks vidmate w3toys
                    How do I update my TX6 Android box?
                      Firmware Update Guide for TV-Box with Allwinner SoC [APCTV]
                        hello, can someone please share a working link for TX6_H6_8822-9_4Gddr_20190722
                        Image: TX6_H6_8822-9_4Gddr_20190722.img
                        Archive file size: 744 MB
                        Platform: Allwinner H6 or tx6-9.0-20190615
                        Image: tx6-9.0-20190615.img
                        Archive file size: 883 MB
                        OS: Android Android 9.0 stock ;; all links i have found are dead or file no longer available.Even @TanixBox.com Please. Need Desperately. Thank you in advance
                          Originally posted by Burn1down View Post
                          ...share a working link for TX6_H6_8822-9_4Gddr_20190722 ..... all links i have found are dead or file no longer available.Even @TanixBox.com...
                          check under YT video description ;-)
