For the first time, I can choose the OS Android or Windows.
Then, I try to update the Windows, but then, the OS can operate only for Windows and the Android disappears.
From that time, I could run only for Windows.
Now, the Windows asked me the PRODUCT KEY,
Where I get the PRODUCT KEY? I see in the box or manual, there are no PRODUCT KEY information.
Do I must reset my mini pc to factory default, so it will be back, that I have Android and also Windows that is no need PRODUCT KEY?
How to enter the BIOS?
Now I use Wireless Keyboard & Mouse.
Thank you.
