I need custom rom for Alfawise a8 (RK3229)
    Hi Guys
    I bought The Alfawise A8 two weeks ago but i dont like its rom and launcher. I tried to burn a firmware with USB CABLE but this device did not defined by my pc, because i think Alfawise A8s usb port is not working. i have a sd card and i can burn firmware only with sd card. Did you have custom rom link for RK3229? (RedPoison, atvxperience or other stable rom)
    I am from TURKIYE and sorry my english.
    Originally posted by atacr View Post
    .... I tried to burn a firmware with USB CABLE but this device did not defined by my pc, because ? think Alfawise A8s usb port is not working. ?
    you have to push/hold reset button...
    stock FW with instructions...
        thanks bro,
        but USB-4 is not working. How can i burn to sd card this rom?
          Firmware Update Guide for Android TV-Box with Rockchip SoC [androidpctv.com]
            thanks broo
              thanks bro,
              I use the Rockchip Create Upgrade Disk Tool v1.59 or 1.53. Always worked with me.
