Like most SBC boards they are more designed i think for systems other then Android
Anyway another user found a version of android that works but it needs patched for somethings to work.
I cant seem to get into the recovery mode, it may not even have one? It does have a "uboot" button to put it into a mode for flashing the emmc module
The only way i know how to use TWRP is threw the recovery mode, is there another way to run TWRP?
When working with the pi4 there was a mode in the developer options called terminal but this version of android doesnt seem to have that, i think on the pi4 it was linage maybe only that system has the terminal?
Can i patch a file using the burning tool with an A-A usb cable?
Maybe boot TWRP from an SD card?
