[Solved]Magicsee N5 bricked
    Dear Friends,
    can anyone help today briceked my Magicsee N5 device?
    I have only red light and on uart console looped this :
    BL2 Built : 15:21:18, Aug 28 2019. gxl g1bf2b53 - luan.yuan@droid15-sz
    set vcck to 1120 mv
    set vddee to 1000 mv
    Board ID = 12
    CPU clk: 1200MHz
    DQS-corr enabled
    DDR scramble enabled
    DDR3 chl: Rank0+1 @ 768MHz - FAIL
    DDR3 chl: Rank0 @ 768MHz - FAIL
    DDR3 chl: Rank0 16bit @ 768MHz
    bist_test rank: 0 1c 00 39 33 15 51 20 00 40 37 18 57 2e 2e 2e 2c 2c 2c 2c 2c 2c 2c 2c 2c 731 - PASS
    Rank0: 1024MB(auto)-2T-11
    AddrBus test pass!
    eMMC boot @ 0
    sw8 s
    emmc switch 3 ok
    Authentication key not yet programmed
    get rpmb counter error 0x00000007
    emmc switch 0 ok
    Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x00004000, part: 0
    New fip structure!
    Load bl30 from eMMC, src: 0x00010200, des: 0x013c0000, size: 0x0000d600, part: 0
    Load bl31 from eMMC, src: 0x00020200, des: 0x05100000, size: 0x0002b400, part: 0
    Load bl33 from eMMC, src: 0x0004c200, des: 0x01000000, size: 0x0007d600, part: 0
    NOTICE: BL3-1: v1.0(release):53f813e
    NOTICE: BL3-1: Built : 15:51:23, May 22 2019
    [BL31]: GXL CPU setup!
    NOTICE: BL3-1: GXL normal boot!
    NOTICE: BL3-1: BL33 decompress pass
    mpu_config_enable:system pre init ok
    dmc sec lock
    [Image: gxl_v1.1.3390-6ac5299 2019-09-26 14:09:24 luan.yuan@droid15-sz]
    OPS=0xc4
    Wrong chip c0
    GXL:BL1:9ac50e:bb16dc;FEAT:ADFC318C:0;POC:3;RCY:0; EMMC:0;READ:0;0.0;CHK:0;
    TE: 187247
    Thakns!
    Solved!
    These two pins need shorting, then reflashing with USB BURNER.
