Use an sd card and load coreelec. Use the latest version of coreelec and as dtb file use the generic one which has "ng" in its name, it is for 4G memory (has "4G" in the name) and also is for 1Gbit LAN ("1Gbit" in the name of the file). REMEMBER to RENAME the file you will use to "dtb.img".
H96 Max X3 BT WIFI Ethernet problems
Another thing you can try to check if your wifi chip functions OK and it is not damaged.
There is a new firmware u215 dated from 12/08/2020 https://drive.google.com/drive/folde...-TPyiK236-Hu1f
Maybe you can try it to find if it solves your problem with the wifi
Originally posted by ath156 View PostThere is a new firmware u215 dated from 12/08/2020 https://drive.google.com/drive/folde...-TPyiK236-Hu1f
Cheers!!
Originally posted by mdherwin View Post
Hey man, thanks for the heads up! Sorry I've been busy, I'll take a look and let you know the outcome once I tried it
Cheers!!
Hello. Sorry if it's not a suitable thread, but I haven't found another one.
Please, I need help. Have H96 X3 Max
How can I close applications in the background? I can't do this with ALT + TAB + DEL because my airmouse doesn't have a Tab key.
Please, I tried everything and I can't get anything. thankful
Originally posted by AllanSEP View PostHello. Sorry if it's not a suitable thread, but I haven't found another one.
Originally posted by RiCkLaR_atvX View Post
IF you are using the standard AOSP_mobile/tablet ROM that comes from factory, then you can go to Google PlayStore and download either Greenify or Killapps, then if using a mobile/tablet laucher like Lawnchair can set app widgets for either app to quickly kill or hibernate any background apps. I usually have both of the apps mentioned installed in my boxes, even if it is an ATV rom I will sideload Greenify.
Of course what RiCkLaR_atvX suggested is a good option, but if I were you I would also try a custom firmware.
If somebody has this box with Blue Board and wifi chip IT6334 I have made a new version for it here https://forum.freaktab.com/forum/tv-...880#post816880
I don't know if everything is correct since I own one H96 max X3 with green board and I borrowed the files from somebody else. But you can give it a try and report.
At the beginning of the topic there is a board with WP6334. I don't know if this is the same as IT6334, but you can try.
EDIT : It is confirmed that this version is OK for IT6334 (both wifi and BT are functioning properly)Last edited by ath156; 22 November 2020, 21:27.
The above version for IT6334 is confirmed to be OK !!!!!!! https://forum.freaktab.com/forum/tv-...880#post816880
There are currently 1630 users online. 3 members and 1627 guests.
