Station P1 RK3399 Custom Android Q ROM
Originally posted by estival View PostThat's good news. I'm looking forward to it?Thanks
Here is the new AndroidTV 10 firmware.
You can use AptoideTV to install AndroidTV apps or sideload apk files from storage and access them in the AppDrawer, 1st banner on the homescreen.
Station P1 AndroidTV 10 Firmware https://i.ibb.co/xfkdNF8/Homescreen.jpg Changelog v1.0 Add AndroidTV bootanimation Fix ATV Play Store Fix Youtube VP9 freezes Add Ad-blocker(blocks > 300000 sites) Add Kodi, Nova VideoPlayer, SmartTube Next, MiXplorer apps Grant storage permission for installed apps Changed default
Originally posted by smtit View Post??????? ????? ?????. ???????, ??? ??????? ????????? MEZZ ?? Android?
Since this firmware is for ROC-RK3399-PC-PLUS with different hardware it can't work.
Do you have a ROC-PC-RK3399 then it can work on stock Android 10 firmware, I can also check if I can make a ROC-PC-RK3399 Android 10 firmware then.
Originally posted by smtit View PostI have a Station P1. Is this a ROC-PC-Plus? Sorry, I don't know much about it. I am a regular user, I can only download the firmware and install it.
This firmware runs on both devices.
But the ROC-RK3399-MEZZ-M2-POE expansion board for Android only works on the ROC-RK3399-PC(predecessor to ROC-RK3399-PC-PLUS).
Originally posted by smtit View PostTell me, is the problem in the drivers or is the board not compatible at all? After all, there are the same connectors on the motherboard. Will any expansion board fit these connectors? How can I connect an ssd m. 2? Without using external connectors.
It seems people did manage to use the ROC-PC-RK3399 expansion board with the Station P1
but only with Armbian Linux so far.
You have to remove the case and use different screws then it works.
For Android, you will need to put a different u-boot on the SPI flash.
I saw some patches for other devices already.
Perhaps I can get all the patches and ask others if they can test it.
Then you should be possible to boot from USB, EMMC, sd-card, nvme.
Thanks. I read the entire article and its discussion at the link provided. So far, everything is difficult for me. I already bought the expansion board. I'm waiting for her to arrive. Then I will try all the recommendations for installing it in the case. And I'll think about how to do it technically. I have straight hands, but I will need help in developing and installing patches. I don't think I'm the only one thinking about it. And it will be a help for many.
Originally posted by smtit View PostThanks. I read the entire article and its discussion at the link provided. So far, everything is difficult for me. I already bought the expansion board. I'm waiting for her to arrive. Then I will try all the recommendations for installing it in the case. And I'll think about how to do it technically. I have straight hands, but I will need help in developing and installing patches. I don't think I'm the only one thinking about it. And it will be a help for many.
? ??????? ????? ?????????? ROC-RK3399-MEZZ-M2, ????????? ?? ? ???????? ????? ??????? P1, ??????? Android ?? ?? ?????. ???? ?????-?????? ??????? ? ???????
There are currently 1823 users online. 2 members and 1821 guests.
