CPU TEMP?
Re: CPU TEMP?
Originally posted by PHYSC View PostCan anyone tell me a way to get the cpu temperature reading on my K-R42,or is there an app for this, as all apps ii have tested so far are useless for finding the cpu temperature?
leolas.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Re: CPU TEMP?
Originally posted by PHYSC View PostThat is a major let down,i hope someone cracks it soon then as i want to know my temps asap.
SENSORS
Originally posted by leolas View PostExternal sensors is the best option, in all the sources I saw, there is some references to temp sensors, but they are with a fixed return value. So I think you must not expect they work soon
leolas.What is the world if you don't explore?
Originally posted by convict View PostHave you tried antutu test?What is the world if you don't explore?
Originally posted by PHYSC View Postpretty sure I did when I 1st had the tv box I'll try it,what's the average score for the k-r42.I put up a thread recently with a cooling mod and the box skinned in kevlar,I shimmed and fitted a copper heatsink with an 80mm fan.So as you can imagine I am keen to benchmark and check the temps.
SCORE
Originally posted by convict View PostI saw your mod and it's awesome. Average antutu benchmark for k-r42 is about 14 to 15k and and average temp is 35 to 40 celcius given that it is a heatsink model
There are currently 1777 users online. 3 members and 1774 guests.
