a95 fx3 notification
You’ll see the notification bar, but you won’t be able to access it.
I believe this is due to the implementation of Android 9 that the manufacturers made.
As it has a good cost benefit alive with this limitation without problems.
Suggestion: Go to thread A95X F3 Amlogic S905x3 8K Video Decode Android 9.0 TV Box RGB Light 4GB/32GB, where you will find more tips on the A95X F3.
Originally posted by blackice101 View Posti cannot find a twrp version for my box
can you help me
thank youA95X F3 Amlogic S905x3 8K Video Decode Android 9.0 TV Box RGB Light 4GB/32GB https://image3.geekbuying.com/content_pic/201910/A95X-F3-Amlogic-S905x3-8K-Video-Decode-Android-9-0-TV-Box-4GB-32GB-20191010151934882.jpg Highlights as Found Amlogic S905X3 applies quad-core Cortex-A55 processors, which is described as an
There are currently 909 users online. 0 members and 909 guests.
