I'm a newbie to electronics, but really interested in this field, so I'm trying to fix an HK1 mini Android tv box for a family member.
The HK1 mini with the RK3229 chipset doesn't show a picture on the screen. It also doesn't show the blue light to indicate that it's turned on. This is what I've done:
- Measured the charger. The charger measures 5,2V which is correct for this charger of 5V
- Other HDMI cable, still no picture
- Opened the case, this is where it gets interesting. A small blue and red light on the board simultaneously light up. These lights weren't visible before opening the tv box.
After reading up a bit (on this forum) I guess it's bricked or worse. So I tried several Rockchip PC tools and different USB cables. Also different sequences of pressing the reset button behind the audio port, connecting the DC power, USB cable etc etc. My PC just doesn't recognize the HK1 mini. I installed the Rockchip Drivers before trying anything.
Firmware used: RK3229_HK1_MINI_SSV6051_9_20190919.1347.img
Even with formatting a micro sd card in FAT32 format with the correct image files nothing happens.
Can someone point me in the right direction? Lastly, I also tried to short circuit a couple of connection points but that didn't show up the HK1 mini on my PC either.
Many thanks! This is a short journey for me so any help is much appreciated
