Specification as Found
Brand: MECOOL Model: K5 Type: TV Box GPU: Mali-G31 System: Android 9.0 CPU: Amlogic S905X3 Core: Quad Core RAM: 2G RAM RAM Type: DDR4 ROM: 16G ROM Max. Extended Capacity: TF card up to 64GB (not included) Color: Black |
Decoder Format: H.263, H.264, H.265, HD MPEG4 Audio format: AAC, AAC, FLAC, AVE, MP3, OGG, RM, WMA, WMV Video format: VP9 Profile-2 up to 4Kx2K @ 60fps H.265 HEVC [email protected] up to 4Kx2K @ 60fps AVS2-P2 Profile up to 4Kx2K @ 60fps H.264 AVC [email protected] up to 4Kx2K @ 30fps Photo Format: JPG, JPEG, BMP, GIF, PNG, JFIF ... etc photo format Support 5.1 Surround Sound Output: Yes |
5G WiFi: Yes WIFI: 802.11 a/b/g/n/ac Power Supply: Charge Adapter Interface: AV,DC 5V,HDMI,Optical,RJ45,TF card,USB2.0,USB3.0 Antenna: Yes Language: Multi-language HDMI Version: 2.1 Other Functions: DLNA,Miracast,Others HDMI Function: HDCP Power Consumption.: 5W RJ45 Port Speed: 10/100Mbps |
Power Type: External Power Adapter Mode Power Input Vol: 5V Power Adapter Input: 100-240V / 50-60Hz Power Adapter Output: 5V 2A |
Remote Controller Battery: 2 x AAA Battery ( not included ) |
Product weight: 0.1650 kg Package weight: 0.3800 kg Product size (L x W x H): 13.00 x 10.90 x 3.18 cm / 5.12 x 4.29 x 1.25 inches Package size (L x W x H): 18.60 x 14.50 x 7.00 cm / 7.32 x 5.71 x 2.76 inches |
Package Contents: 1 x TV Box, 1 x Remote Control, 1 x Power Supply, 1 x HD Cable, 1 x English Manual https://www.gearbest.com/tv-box/pp_009888153269.html?wid=1433363 http://gbe.st/302xIw2: |
