Amlogic S905L2 TV Boxes
    A find form CNXSoft
    Low-cost Amlogic S905L2 TV Boxes Show Up on Aliexpress for $20+
    Amlogic has plenty of variants to its S905 processors, and so far I had never heard about Amlogic S905L2 processor that can be found in some Android 9.0 TV boxes sold for a little over $20 including shipping.
    There are only two such TV boxes listed with the quad-core Cortex-A53 processor so far, and they are basically the same X7 model except for different storage and memory configuration.
    X7 TV box specifications:
    • Amlogic S905L2 quad-core Cortex-A53 with Arm Mali-450 MP GPU
    • System Memory – 2 or 4GB DDR3
    • Storage – 16GB or 32GB flash storage
    • Video Output – HDMI up to 4Kp60 with HDR support, and AV port
    • Video Decoding – 4K H.265, H.264
    • Networking – 10/100M Ethernet and dual-band 802.11b/g/n WiFi 4
    • USB – 2x USB ports
    • Power Supply – TBD
    • Dimensions – 105 x 105 x 12 mm
    The device ships with a power adapter, an IR remote control, an HDMI cable, and a user manual. It’s quite hard to find any info about S905L2 processor, but it should be similar to the Amlogic S905L processor found in some Xiaomi TV boxes which explains why VP9 is not listed as a codec. One of the differences could be that while S905L supports only up to 2GB RAM, S905L2 can handle up to 4GB.
    While S905L2 is mostly new to “The Internet”, some financial document shows a significant number of S905L and S905L2 processors were sold to Skyworth (??) in 2018, as well as other companies. There’s also an S905L2-B processor likely with a Dolby Audio licenses.
    hmm, thought it was typo and going to be a S805Y2 1080p chip found in the new Xiaomi stick but in a box this time, but nice find on those financial documents.
      Do not buy this box
      There is a large factory fraud
      Specifications are not correct
      The device reads the specifications of 32 GB and 4 GB RAM and Android 10
      But actually it is 1 GB and 8 GB
      Android nogat 7.1
      Also, there is no support no firmware
      Not support cpu sensor temperature
      Another problem is the device freezes and needs unplug power and restarted
      Only i like in this box. Dual wifi but 5G give you Full Speed
      And the box support navigation bar and notification bar
      Here are the pictures
        Where to download firmware
          My friend buyed 4 from these Boxes and now he is ****ed so i start to upgrade them to duoble all inside ( Ram and Rom )
          her is a link to an guy who make a little bit Softwork for these Shit it includes 2 Roms for the AML Flasher who works.
          unpacke from p211 dtb. Contribute to 52571abc/gxl-s905L-B-p211 development by creating an account on GitHub.
          or you look on Gearbest where this plaque starts.
