Originally posted by shaunmt
View Post
It's mostly safe... you can do some damage with the terminal app and dd command if you're overly careless... but you'd have to stray really far from the instructions here to damage anything...
The scripts are installed via an option in the app from the play store. That part is simple. Just download the apps from the play store (links are in the first post) and follow the instructions in the first post.
It does require root.
The only part that might differ will be the partition layout and file paths.
ShaunMT
ShaunMT
