[Rom] Android 11 for S912
    Do you know anyone who can convert A11 AOSP to ATV? or is there a guide to follow?
      if you ask sergej_a_g on the 4pda.ru forum, maybe you might get a reply. It's a Russian language only -forum.
        I dont have an account or create one on 4pda and since its Russian only
          Yeah, pretty daunting ..google translate...uugh! You end up interpreting the suggested English.
          * Search for Android 11 and browse around their media box forums.
          ** SOC Amlogic Development
          *** If I understand, it is the framework-res.apk which can be modified to make the system appear either AOSP or ATV. The trouble comes that Playstore and other Google apps have to be properly replaced for the modified platform.
          **** It would be easier to get an ATV launcher (several available) that simulate the ATV desktop.
            Maybe flashing gapps for atv? I'm looking for a 64 bits build, of corse one stable enough for daily driver.
              x64 build is over-rated 2020-2021. If you are multi-tasking and encoding at the same time...sure very necessary.
              Watching Youtube while E-mailing ...not so important.
              With wifi 6, 10Gb Ethernet, ATMOS , HDR, HDMI 2.1: 48Gbps, usb3.1+ and mass storage, x64 will ramp-up and be adopted as the norm.
                Nothing concrete, not sure if any dev is working on it
                  I somehow like the x64 build by highwatstar, its sleek and fast and no crappy mods
                    Sometimes I got apps build for X64, it's a main reason.
                      This build is here in freak tab?
                        I've seen no reference here, but, that means very little.. .
                        XDA forums have a massive amount in development.
                          I was referring to atv android 9, there are couple of links for android 10 and 11 but that's pure aosp with minor bugs
                            Yes,but very limited development for android boxes
                              Yep, I looking for ATV too, but I confess, I'm a little confused with those build. At this moment I'm using atvxperience on my beelink GT1 Ddr3 (2gb/16gb), besides some annoying bugs, it's working well. But I'm looking for some 'better' build than I running now. Some of those little bugs drive me crazy sometimes.
                                LineageOS 18-1 beta
                                This is not ported, but, included for the budding dev.
