MAGICSEE C500 PRO DVB-S2/S2X/T2 4GB/32GB S905X3 A9 Dual WIFI BT 2.5 Inch SSD/HDD Bay PVR Recording
    MAGICSEE C500 PRO DVB-S2/S2X/T2 4GB/32GB Amlogic S905X3 Android 9.0 TV BOX 2.4G+5G WIFI Bluetooth 2.5 Inch SSD/HDD Bay PVR Recording
    Highlights as Found
    Amlogic S905X3 SoC based, the C500 PRO is a brand new model pre-installed with Android 9.0 from MAGICSEE. It is fully compatible with the DVB S2/S2X/T2 MPEG-2/4 H.264 Standard.
    DVB - T = T for Terrestrial, that means you pick up the signals with a terrestrial aerial.
    DVB -S = S for Satellite, you pick up the signal from a satellite dish. DVB-S2X is an optional extension of DVB-S2 standard
    ATSC = An American set of standards for digital television transmission over terrestrial, cable and satellite networks.
    Amlogic S905x3 Quad-Core SoC alongside 2GB/4GB of RAM,16GB/32GB of eMMC storage options will ensure better-than-average performance. 3D gaming should also be pleasing since the Mali-G31 GPU is involved.
    Connectivity is complete with 1 x USB 2.0, 1x USB 3.0, 1 x LAN, 1 x SPDIF out, 1x HDMI 2.0a (4K and HDR support) out, 1x A/V out (in a 3.5mm jack form) and a single SD slot. And most important of all is the hybrid part, so at the back, we can find the input for the terrestrial and satellite signals.
    For wireless connections, Magicsee C500 PRO supports both Dual Band AC and BT4.2 protocols.
    Geekbuying
    MAGICSEE C500 PRO DVB-S2/S2X/T2 ATSC,
    2GB/16GB, or 4GB/32GB S905X3 A9 Dual WIFI BT 2.5 Inch SSD/HDD Bay PVR Recording
    MAGICSEE C500 PRO DVB-S2/S2X/T2 2GB/16GB Amlogic S905X3
    $103.99 after coupon: 4VQ7OUI6 [CN Warehouse]
    https://www.geekbuying.com/item/MAGI...AGICSEEC500PRO
    MAGICSEE C500 PRO DVB-S2/S2X ATSC 2GB/16GB Amlogic S905X3
    $109.99 after coupon: 4VQ7S0VG [CN Warehouse]
    $119.99 after coupon: 4VQ7PSNZ [CN Warehouse]
    MAGICSEE C500 PRO DVB-S2/S2X ATSC 4GB/32GB Amlogic S905X3
    $129.99 after coupon: 4VQ7SILZ [CN Warehouse]
    Geekbuying
      I have a Magicsee C500 Pro T/T2, 4gb Ram, 32gb Rom, but the android stopped working. Now I urgently need an image file (img) of the firmware of the TV box to revive it via USB Burning Tool through the computer. The program only reads img files. Only with this program can I revive it. I tried everything else and it didn't work. I will be very grateful if someone helps me with working img firmware for Magicsee C500 Pro.
