I just got a few X96 Max Plus2 4/64 that i want to install TWRP on so i can do full backups
They came with the latest update on them, X96Max_Plus2_20200818-2014_4GB_update
I searched and found this thread but i need a little more details
that said TWRP 3.3.1 worked on this box but was with an older update, i assume that .img file still works with 20200818-2014 update.
Is there a Guide i can follow that someone can point me to. As i am not sure i know enough to not make a mistake from that post alone.
I did this on my old box X96 Max a few years ago and i had to install Reboot Recovery and copy the TWRP.img file to and SD card i think, Is that required for this new box with PIE,
Or can i just use the built in stock reboot menu and install from external
I am just trying to not guess my way through this.
Thanks for any help
