XBMC HD video after about 45 minutes unwatchable because of framedrops
    I have a Tronsmart CX919 with Nexus SDK 1.2 and 1080p stock kernel.
    Install different versions of XBMC always with HW support. Now 13 alpha 8 september release.
    Videos play great without problems. HD content play very smoothly!
    But the problem is that this is for 45 minutes or so.
    After that time there are much framedrops that the video being unwatchable
    Pauzing doesn't help, only stop/start the video does help for another 45 minutes.
    I read something about the audio and that audio on XBMC must set to 'Analog'
    but no result.
    Tried different kernels from Finless and Sam321(because of his tweak against the mouse movement framedrop) But always after about 45 minutes I must stop/start the video.
    1Channel can resume the video but IceFilms can't.
    I prefer not to use an external player because of the automatic subtitles of XBMC.
    Does anyone know this problem and has maybe a solution, better workaround available or a direction to search for it?
    Thanks in advance
    'cache' running full?
    do you have enough space?
    did you try editing or creating 'advancedsettings.xml' ? ( search freaktab )
    Cheers..
      did you try editing or creating 'advancedsettings.xml' ?........
      Yes, it was my first thought too.
      I have made the cache 100MB, because of these framedrops.
      I see this size always is being filled on the timebar and with key O. Wifi speed looks OK too
      But result is always the same. Framedrops after about 45 minutes.
      Also the use of OC kernel (gpu-ram) hasn't work.
      My XML:
      <advancedsettings>
      <network>
      <alwaysforcebuffer>1</alwaysforcebuffer>
      <readbufferfactor>4.0</readbufferfactor>
      <cachemembuffersize>104857600</cachemembuffersize>
      </network>
      <video>
      <stagefright>
      <useavccodec>1</useavccodec>
      <usevc1codec>1</usevc1codec>
      <usevpxcodec>1</usevpxcodec>
      <usemp4codec>1</usemp4codec>
      <usempeg2codec>1</usempeg2codec>
      <useswrenderer>false</useswrenderer>
      </stagefright>
      </video>
      </advancedsettings>
        Same problem here
        Hi
        I have exactly the same problem. I have a Mac Mini and run Frodo. Anybody already found a solution ?
        Frank
        [email protected]
