After buying my minix x7 I've followed the endless discussion about running the CPU capped with min. 1200mhz and personally was feeling a little bit uncomfortable about this way to fix a video speed problems. I thought to myself why can't I just make it run this way only when needed to play a video and run in lower speed when just sitting idle?
I think that I've finally found a way to achieve this.
I took the kernel of 006c and patched it with modified version RKPatchomatic tools from phjanderson, thus keeping the (IMHO) required GPU and DDR overclocking (or, more precisely, un-underclocking
So far everything seems to run fine and does its' job.
I've uploaded the modified kernels here so you may try it by yourself.
The 1608mhz kernels are working in 312-1608 range, and the 1704 are working in 504-1704 range.
The SetCpu is not a free app, but you can try Cpu Adjust that supposed to allow the same results.
So here we go, try it and tell the rest if this helped or your minix were blown up in fire
