[ROM][S905X] Aidan's Custom 9.0 Xiaomi Mi Box Firmware Port [ATV 9.0]
    This is v3 Beta Of My Xiaomi Mi Box 4 (Mi Box S) Android 9.0 Firmware Port Thanks To Project Treble
    This Is A Firmware Port Of The Xiaomi Mi Box 4 (Mi Box S USA) Firmware Designed To Run On Amlogic Devices (And Maybe More But Untested)
    This Firmware Is FAST & STABLE
    WARNING: This Is Experimental Please Read About "Mask Rom Mode" To Know How To Recover Your Device If Installation Fails!
    This Has The New Amlogic Kernel And As Such Will Not Work On All S905X Devices, My Older Android 7 Based Firmware Works On Most Devices
    NEW Website! Check it out & Download
    https://aidansrom.ml
    How To Install:
    See The Website
    Extra Thanks To DiogoSilva48 Too
    https://aidansrom.wordpress.com/
    How To Install:
    See The Website
    wow great job on this image works great..i am testing this on a tx5 pro..wish i could get a wireless ps3 remote to work on it..other than that awesome job
      awesome glad it runs well for you
        will this run on an x96 s905x 2gb/16gb???
          yhea it should
            hi there rom is working very good..but just yesturday its coming up with a update it down loads then it crashes durring install ...?just currious if you noticed it yet
              hi, yhea i have seen this and will manually patch the update and release a new img (v7) as soon as i can
                thank you
                  Can you do s912 minix neo u9h Firmware v7 usb to work on you Firmware
                    probably not, if you could find a android 9 firmware that will flash then it may be possible to try somthing
                      I did flash one of your firmware v4 on my s912 Minix neon u9h the remote won't turn off box and USB not working. And update ota fail.You fix that and it will be a hit.
                      1. [v4] [S912] [DDR3 & DDR4] [LAN1000] Aidan's Custom ROM this was the firmware that I put on my minix neo u9h.
                        How To Install:
                        See The Website
                        Can't find the download link for v3 xcan you advise please ?
                          V7 is now availible, the download link is in the YouTube video description
