CX-921
Originally posted by fasttimes View PostAnyone order this box or have one? Don't see any custom ROMs yet, spec's look like Minix neo x7. Seems like a good box from the spec's and comes with a full size remote. Cheaper than a neo x7 by a good chunk of$.
Today I’d like to share with all the stock firmware for CX-921 Quad Core TV Box with Bluetooth Function, and the update method, the same method with K-R42 1 Download […]
I hope some developer can have a look at the stock rom,and help to make a great custom roms.
thanks
EricLooking for developers
Re: CX-921
Originally posted by geekbuying View Postyes,the cx-921 is a good tv box, we have posted the stock firmware here:
thanks
Ericand please can you tell me what is the WiFi and bt chip in this stick? If anyone have free time I will try to make a custom rom mod for it and a cwm recovery for it.
I will need a tester for it.
leolas.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Im thinking about buying x7 mini why was it a mistake buying this? I too find the x7 and mini nice consept but price is way too high iI too rather have the ugoos cx921 or even the stick qc902 for half x7 price
Btw realtek 8188 wifi I think on cx921Minix neo x7 custom quickshot V3.1 kitkat with cpu1700 video stock and oc ram 720 kernal
HTC Amaze 4g unofficial cyanogen mod 11 KitKat 4.4.4
ASUS Nexus 7 (original 2012 tegra 3) Cyanogen mod 12 Lollipop 5.0.2
There is no rom development for the mini x7, so for instance i have a powered usb hub and the minix stock rom doesn't like when i plug a external hard drive into it, it will shutdown and reboot, my mk808 with the last finless rom, no problem. Just one example but if there are any bugs in the factory rom for any of these boxes your out of luck unless the coders work with it, none for the mini x7 or the cx921 so far, my 2ยข
thanks
Eric
CX921 linux working network needed
Hi all, this is my first post here so please remove this reply to the correct place if it's wrong.
I had this device
totaly bricked and then i gave it to a familiar to me service person and guest what? He fix it with a small fee! He told me that he desolder the nand chip and reprograming it. He managed also to put picuntu 13.0.4. inside. But there is one problem:
I want this device to have linux to install a bitcoin mining software and use it as a miner for my bfl labs mining device i have.
The problem is that i can't so far managed to have a working network (either wired or wireless)
Is it a way to do some tests?
Does anybody managed to fix this networking problem?
TIA
There are currently 897 users online. 0 members and 897 guests.
