Hello everyone! I'm bothering you with a concern ... I'm thinking of unrooting my tv box because I can't install any app from playstore ... Is it possible that it continues to work fine after unrooting it? Or am I in danger of ruining it? Thanks and regards! (sorry for my english...)
Help me, please...Pendoo X 10 Plus
Hello everyone! I'm bothering you with a concern ... I'm thinking of unrooting my tv box because I can't install any app from playstore ... Is it possible that it continues to work fine after unrooting it? Or am I in danger of ruining it? Thanks and regards! (sorry for my english...)Tags: None
Originally posted by bark View PostHello everyone! I'm bothering you with a concern ... I'm thinking of unrooting my tv box because I can't install any app from playstore ... Is it possible that it continues to work fine after unrooting it? Or am I in danger of ruining it? Thanks and regards! (sorry for my english...)
"root" can not really make this , think it is another Problem , remember this Pendoo Roms for sure
full of Bugs , try a Factory Reset , or wipe all data & cache of the Google Apps ,
think your better with a CustomRom for S905x3 , if right Wifichip is supported by CustomRom ,
that is the Problem with this cheap Boxes ,
hope you find a Solution , good luck / gefattern
Reboot and try again.
Originally posted by bark View PostHi! I can't install google play store apk. Maybe I should uninstall the play store application that comes pre-installed at the factory? If so, how do I uninstall it? Thanks !!!
If the above are not enough you can try the following (step 3 is the same as above) :
1. Remove "cache" from both apks2. Reboot.See if the issue is resolved.3. Go to the Playstore settings and click once the version number. Wait to update.4. Set automatic time from the INTERNET (in SETTINGS). Better to do it as a 1st step (if you haven't enabled it yet)
There are currently 1486 users online. 0 members and 1486 guests.
