A95X F3 Air - cannot turn off lights
simplest solution black electrical tape
my solution, open box (I have the RGB version) remove 4 screws, open carefully, remove 2 screws what hold the led mount and white diffuser in place.
put electrical tape under the board and around the open contact. remove white diffuser, put led board on mainboardand screw box close.
benefits: led does not nother anymore because light is very dimmed plus you have an improved thermic since you have a stylish opening on top.
Works very well for my a95x f3 rgb.
Originally posted by mrx777 View PostColorLED Setting app keeps stopping when I try and adjust settings. Tried stopping app and clearing cache, no fix. Any help would be much appreciated.
Is the Color LED Setting App a system app?
Or add on application?
If system app you wont be able to uninstall
However you should be able to disable
There are currently 2898 users online. 0 members and 2898 guests.
