M8S+ android 4.4 ver 0.95
Need Ram/Wifi/Nand/eMMc...
Image that ends in 659
Was there anything written on sticker like 1 / 8 or something to indicate Ram/Memory
Flip the Board over and look for stickers/writing on board
Take a Pic
Image that ends in 956
Can see Nand but cable to LED display is covering Markings(need close up / or what is written on it)
To the left of Nand is CPU with Heat Dissipate
Above that are 2 chips...Looks like Ram..(Need close up Or what is written them)
Can,t make out Wifi possibly AP 6330...
Pic of Front /Top side showing whole board
Pic of Back/Bottom side showing whole board
Would help alot !!!!!
There is A Rom for you
Or maybe LibreElec AlexElec
That will work in Garage
Just need more info
there is nothing written on the wifi board and the only numbers i posted in the pics.Libreelec wont work as im not using kodi on this just free apks and a few paid ones live tv.I may have to scrap the idea just thought there may be a file that would work for wifi or ethernet eithor would do.I tried 8 different files 6 other images all fail at 2% and 2 by sd card box just reboots or goes to recovery you would think out of all those one would write to the box as ive flashed dozens of these in the past.
Originally posted by piperider View Postthere is nothing written on the wifi board and the only numbers i posted in the pics.Libreelec wont work as im not using kodi on this just free apks and a few paid ones live tv.I may have to scrap the idea just thought there may be a file that would work for wifi or ethernet eithor would do.I tried 8 different files 6 other images all fail at 2% and 2 by sd card box just reboots or goes to recovery you would think out of all those one would write to the box as ive flashed dozens of these in the past.
That is why you need the info i posted about
There is 5.1 upgrade for box
Try MXQ Project
XDA
C gadgets review
And of course here at Home F-TAB
At best you have a 1 G Ram with 8G nand flash
And very likely 512 MB of Ram with 8G nand
Have converted many to gaming Rom emulator
AlexElec runs very well on the old s812(-
Its probly best to not use in garage
Happy testing
Originally posted by piperider View PostHmm i assumed this was a 2gb box as i never seen an M8S+ that was 1gb of ram i had several over the years
https://www.gearbest.com/tv-box-mini-pc/pp_226779.html
They will be in OTA format (Compressed/Zipped/need to use SD Card method)
They read as the following
KII-userdebug- 5.1.1 LMY47V 20151216 test-keys
m8S+-userdebug 5.1.1 LMY47V 20160623 test-keys
Happy Testing
There are currently 4805 users online. 2 members and 4803 guests.
